Shift SubOpportunities
This user property is used to send instructions to the code as to whether or not to shift subopportunities during the in-line modification of an arrival date. The default value is Y.
Shift SubOpportunities | Description |
Value |
Y or N |
Parent Object Type |
Opportunity business component |
Usage |
This user property is used to send instructions to the code as to whether or not to shift subopportunities during the in-line modification of an arrival date. This user property is used in C++ code. The default value is Y. |
