TNT Manual Allocation Field
Use this user property to set the allocation for the defined field in the case of a per person allocation.
| Property | Description/Value |
Value |
TNT Per Person Allocation |
Parent Object Type |
TNT SHM Quote Item, TNT SHM Invoice Order Item, TNT SHM Order Item business components |
Usage |
The value of this user property is a field, and the per person or system allocation value is set to this field. This user property is used in C++ code to set the appropriate allocation value for the child items of a package. |
