View Aspect: SHM Invoice Detail View
Use this user property to set the event checks with the specified Status fields as read-only records.
| Property | Description/Value |
Value |
TNT_EVENT_CHECK_STATUS |
Parent Object Type |
SHM Invoice Form Applet applet |
Usage |
Sets the event checks with a Status field of Posted or Voided as read-only records. When the user selects these event checks, the SHM Invoice Detail View becomes a read-only view. When an event check is a read-only record, any associated function or line item records are also read-only records. |
