Y-Axis Drill Down Enable
This user property is used to enable or disable drill-down on Y-axis specific spaces.
| Y-Axis Drill Down Enable | Description |
Value |
N |
Parent Object Type |
TNT SHM Function Space Diary, TNT SHM Compact Function Space Diary, and TNT SHM Function Space Diary Total Availability Applet |
Usage |
If the value of this user property is N, then drill-down on Y-axis specific spaces is disabled. |
