Y-Axis Header Display Format
Use this user property to determine the format for the date to be displayed on the Y-Axis header in the Function Space Diary for some time scales.
| Y-Axis Header Display Format | Description |
Value |
MMMM YYYY |
Parent Object Type |
TNT SHM Function Space Diary, TNT SHM Compact Function Space Diary, and TNT SHM Function Space Diary Total Availability Applet applets |
Usage |
Specifies the Y-Axis header display format in the Function Space Diary, for example, August 2008. This user property is applicable only if month and year are displayed on the Y-Axis header. |
