Configuration Options for DB2 Connect
When using DB2 Connect, your configuration options depend on whether you are deploying Siebel CRM on a Web Client or on a Developer Web Client, as shown in the following table.
DB2 Connect Edition | Siebel CRM Deployed on | Install and Run DB2 Connect on |
Enterprise Edition (EE, ASE or UE) |
Siebel Web Client |
Siebel Server computer or another computer on midtier. |
Siebel Developer Web Client |
Any computer on midtier. |
Personal Edition (PE) |
Each workstation. |
The following figure illustrates some of the configurations possible with DB2 Connect Personal Edition (PE) and DB2 Connect Enterprise Edition (EE). DB2 Connect PE runs on the workstation only; DB2 Connect EE can run on the same computer as the Siebel Server or on a different computer. The configuration you choose largely depends on the types of Siebel clients your enterprise supports.
For detailed information about DB2 Connect, refer to the IBM documentation.
