LS Medical Product Issue Populate Report Workflow
This workflow is initiated from the Populate button on the Regulatory Reports view of the Product Issues screen.
The workflow appears in the following figure.
Workflow Description
This workflow performs the following actions:
Checks if current record has already been populated. If it has, the workflow ends.
Sets the data map object according to the report type.
The data map objects are:
LS Medical PI Populate Report - 3500A
LS Medical PI Populate Report - 3500 Supplemental
LS Medical PI Populate Report - MDV Initial
LS Medical PI Populate Report - MDV Follow-up
Populates the report from the product issue according to the data map object.
