Reviewing and Editing the Product Issues
Early in the investigation, the quality manager reviews, updates, and adds information to the product issue record. This record becomes the adverse event or complaint file for the investigation.
There are many fields in the product issue record. Some are filled in by the call center agent, some automatically, and others by the quality manager. Of particular importance are those fields that are used to populate the regulatory reports. For more information, see Regulatory Reporting
This task is a step in Process of Adverse Events and Complaints Investigation.
To review and edit a product issue
Navigate to the Product Issues screen, then the Product Issue List view.
In the Product Issues list, select a record.
In the Product Issues applet, modify the fields in the record as required.
Some fields are described in the following table. Note that the letter and number combination in the last column indicates how this field maps to the 3500A form.
Field Comments Mapping to 3500A Form Account
The name of the account associated with the product issue.
E1
Address
Account address - street address.
E1
Alert Age
The number of days since the product issue was identified as reportable.
If an initial report has been filed, the alert age is the number of days that the product issue was marked reportable before the report was filed.
Alert Date
The date when a representative of a company becomes aware that the event needs to be reported.
For example, when:
A call center agent captures the adverse event or complaint.
An assessment indicates that the event is reportable.
Area
The general categorization area for the product issue.
This field is constrained by Type.
City
Account address - city.
E1
Contacts
(Contact Last Name in list)
The last name of the customer contact associated with the product issue.
These contacts can also be entered using the Contacts view of the Product Issues screen, then the Contacts view.
E1
CSN
Customer service number. A unique number to identify the account.
E1
Evaluation
This field appears in the list applet. It also appears in the form in the Investigation view.
First Name
The first name of the investigator carrying out a particular clinical trial at a site.
First Name
(Contact First Name in list)
The first name of the customer contact associated with the product issue.
E1
Investigator
The last name of the investigator carrying out a particular clinical trial at a site.
If the product issue is associated with a clinical trial, this field is auto-populated with the last name of the investigator at the protocol site, specified in the Protocol number field.
Mfg Report #
This field appears in the list applet. It also appears in the form in the Importer view.
Occupation
Occupation of the contact.
This is copied from the value of the Type field in the Contacts screen.
E3
Open Age
The number of days since the product issue was opened, or, if the product issue is closed, this is the number of days that the product issue was open.
Phone #
Contact’s work phone number.
E1
PI #
Unique number to identify the product issue. It is auto-generated when the product issue is created.
Postal Code
Account address - postal code.
E1
Protocol #
Protocol number identifies the clinical trial at a site. If regulatory report is an IND safety report, enter the protocol number.
G6
Provider
Indicates if the contact is a health professional.
E2
Received (Received Date in list)
The date when a company representative became aware of the event.
Reported FDA
Indicates if initial reporter sent a report to the FDA.
E4
SR #
The service request from which the product issue was created.
State
Account address - state.
E1
Status
The current status of the product issue.
The status of the product issue can be changed by the owner of the product issue, using the Review Complete, Close, and Reopen buttons.
Changes to this field are tracked in the Approvals view.
Sub Area
This further refines the area categorization. (The Area field constrains this drop-down list.)
Sub Status
The Status field constrains this drop-down list.
In the Event Detail applet, modify the fields as required.
Field Comments Mapping to 3500A Form Event Type
Describes the type of event.
B1
Event Date
The approximate date of the adverse event.
B3
Description
(Event Description in the list)
Detailed description of the event
B5
# Occurrences
Number of times the event occurred before it was reported
External Products
List of other medical products (for example, drugs, medical devices) used by patient at the time of the event and dates of use
C10 or D11
Tests/Data
All appropriate relevant test and laboratory findings and dates
B6
Life Threatening
Life Threatening
B2
Disability
Disability
B2
Hospitalization
Hospitalization
B2
Congenital Anomaly
Congenital Anomaly
B2
Relevant History
Relevant history, including preexisting medical conditions
B7
Death
Death
B2
Required Intervention
B2
Date of Death
Date of Death
B2
Other
Describe the reported outcome if it was not covered in the previous selections
B2
In the Products applet, create new records and complete the necessary fields as required.
Field Comments Mapping to 3500A Form Product
The name of the product associated with the event
C1
Lot #
Lot number of the product
C6, D4
Asset #
Asset number for the product
D4
Serial #
Serial number for the asset
D4
Mfg Name
Full name of the manufacturer of the product
D3
Mfg Date
The date the product was manufactured
H4
Expiration Date
Expiration date of the lot or product
C7, D4
Labeled Single Use
Indicates if the device is labeled for single use
H5
Device Operator
Type of person operating or using the suspect medical product on the patient at the time of the event
D5
Device Available
Indicates if the device is available for evaluation by the manufacturer
D10
Return Date
Date that the device was shipped to the manufacturer
D10
Device Type
Generic or common name of the suspect medical device
D2
Reprocessed
Indicate if this is a single-use device that was reprocessed and reused on a patient
D8
Reprocessor
Name and address of the reprocessor of the reused single-use device
D9
NDC#
National drug code #
C9
Part #
Part number
D4
Implant Date
The implant date or best estimate for medical devices that are implanted in the patient
D6
Explant Date
The date or best estimate for medical devices removed from a patient
D7
Street Address
Manufacturer’s street address
D3
City
Manufacturer’s address: City
D3
Postal Code
Manufacturer’s address: Postal Code
D3
State
Manufacturer’s address: State
D3
Model #
Model number
D4
Catalog #
Catalog number
D4
Dose Per Unit
Dosage for each unit of drug
C2
Frequency
Frequency of drug administration
C2
Route Used
Route used to administer the drug
C2
Indication
The indication for which the product was prescribed or used in this particular patient
C4
Therapy From Date
The date drug administration was started (or best estimate)
C3
Therapy To Date
The date drug administration was stopped (or best estimate)
C3
Event Abated
Event abated after use stopped or dose reduced
C5
Reintroduce Reoccur
Event reappeared after reintroduction
C8
Review any service requests associated with the product issue as follows:
Drill down on the product issue record.
Click the Service Request tab.
Drill down on the SR #.
