Setting Up Codes
This task is a step in Process of Capturing and Escalating Adverse Events and Complaints.
Codes allow you to codify many aspects of the AECM process. For example, codes are used to categorize the service request that triggers the adverse event or complaint, and codes are used to categorize the corrective actions initiated at the end of a complaint’s life cycle.
Multiple codes and sometimes codes of multiple types can be specified in one code field.
Think carefully when designing and setting up your code system. Codes are used as search criteria for service requests and product issues.
According to your business needs, you can use:
Industry codes such as FDA patient, device, method, results, and conclusion codes required for the MedWatch 3500A form
Company-specific codes
A combination of industry and company-specific codes
The following table outlines where code fields appear in the Siebel AECM module.
| Screen | View | Field Name | Notes |
Service Requests |
More Info |
Codes |
None. |
Product Issues |
More Info |
Codes |
Copied from the service request when a product issue is created. Codes from the service request record are copied to this field when a product issue is created from a service request. |
Product Issues |
Corrective Actions |
Codes |
Typically, codes of type Corrective Action are entered in this field, although any type of code can be entered. |
Product Issues |
Investigation |
Method Codes |
Only codes of type Method can be entered. |
Product Issues |
Investigation |
Result Codes |
Only codes of type Result can be entered. |
Product Issues |
Investigation |
Conclusion Codes |
Only codes of type Conclusion can be entered. |
Product Issues |
Investigation |
Non-Evaluation Codes |
Only codes of type Non-Evaluation can be entered. |
Product Issues |
Importer MDV |
Patient Codes |
Only codes of type Patient can be entered. |
Product Issues |
Device Codes |
Only codes of type Device can be entered. |
Repairs |
More Info |
Codes |
Typically, codes of type Product Analysis are entered in this field, although any type of code can be entered. |
More Info |
Codes |
Regulatory Reports |
More Info |
Method Codes |
Only codes of type Method can be entered. Copied from the product issue when a regulatory report is populated. |
More Info |
Result Codes |
Only codes of type Result can be entered. Copied from the product issue when a regulatory report is populated. |
More Info |
Conclusion Codes |
Only codes of type Conclusion can be entered. Copied from the product issue when a regulatory report is populated. |
More Info |
Only codes of type Non-Evaluation can be entered. Copied from the product issue when a regulatory report is populated. |
Importer MDV |
Patient Codes |
Only codes of type Patient can be entered. Copied from the product issue when a regulatory report is populated. |
Importer MDV |
Device Codes |
Only codes of type Device can be entered. Copied from the product issue when a regulatory report is populated. |
Activities |
Items |
Code |
Single value field. |
