Defining the Distance Between Two Airports
You can define the distance between any two airports (or city pairs) for air travel in the Loyalty Distance table. The distances listed in the table can be used by a base promotion to calculate the base points for air travel.
To define the distance between two airports
  1. Navigate to the Loyalty Program Administration tab and click Distance.
  2. Click New and complete the following fields:
    Field Comment
    Origination Airport
    The originating airport for air travel.
    Destination Airport
    The destination airport for air travel.
    Distance
    The distance between the two airports (usually in either miles or kilometers).
