Example of a Flight Redemption Promotion
This topic gives one example of setting up the flight redemption promotion. You might use this feature differently, depending on your business model.
In this example, the promotion applies a 25% discount on flights between London’s Heathrow or Gatwick airports and Toronto’s Pearson airport on Bravo Air (BA).
To set up this example, perform the following high-level steps:
  1. Define Origin, Destination City, Partner as Program level attributes (transaction attributes).
  2. Create a new Rule: 25% discount on Redemption.
  3. Define the promotion criteria using the following transaction attributes:
    • If Origin Airport equals LHR or LGW, Destination Airport equals YYZ
    • If Partner equals BA
  4. Define the promotion action as follows:
    • Action equals Redeem Points
    • Object equals Transaction
    • Attribute equals Transaction Points
    • Operator equals Multiply
    • Value equals .25
