ExecuteQuery2 Method for a Business Component
The ExecuteQuery2 method uses criteria form another method, such as SetSearchSpec, to return a set of business component records. Allows you to control the number of records Siebel CRM returns.
Format
BusComp.ExecuteQuery2 ([cursorMode], ignoreMaxCursorSize)
The following table describes the ignoreMaxCursorSize argument for the ExecuteQuery2 method. For information about the cursorMode argument, see ExecuteQuery Method for a Business Component.
Argument | Description |
ignoreMaxCursorSize |
You can use one of the following values:
Used With
COM Data Control, COM Data Server, Siebel Java Data Bean, Mobile Web Client Automation Server, Server Script
