GetProperty Method for a Control
The GetProperty method returns a string that contains the value of a property. If the property does not exist, then this method returns NULL.
Format
controlVar.GetProperty(propName)
No arguments are available.
Usage
You can use the GetProperty method with the following controls:
  • CheckBox
  • ComboBox
  • TextBox
  • TextArea
  • Label
You can use the GetProperty method to get values for the following properties:
  • Background Color
  • Enabled
  • FontType
  • FontColor
  • FontSize
  • FontStyle
  • Height
  • Width
  • Read Only
  • Visible
For more information about these properties, see Properties to Set for a Label in SetLabelProperty Method for a Control.
To return more than one property, you must use a separate statement for each property.
Used With
Browser Script
Examples
The following example uses the GetProperty method to return values for the FontSize, Background Color, Width, and Height properties:
theApplication().SWEAlert("checkbox.FontSize : " +
objCheckBox.GetProperty("FontSize"));
theApplication().SWEAlert("checkbox.BgColor : " +
objCheckBox.GetProperty("BgColor"));
theApplication().SWEAlert("checkbox.Width : " + objCheckBox.GetProperty("Width"));
theApplication().SWEAlert("checkbox.Height : " +
objCheckBox.GetProperty("Height"));
