Logoff Method for an Application
The Logoff method disconnects the Siebel client from the Siebel Server. This method does not return any information.
Format
Application.Logoff
No arguments are available.
Usage
For clients that include a user interface, the Logoff method removes every window except for the topmost window. Logoff also removes every object, except for the topmost object, on the Siebel client and Siebel Server.
If you remove the main object, then Siebel CRM automatically calls the Logoff method.
Used With
COM Data Control, Siebel Java Data Bean, Mobile Web Client Automation Server
