SIS OM Modify Products & Services Process
This workflow determines whether there is an active quote for the current account. If there is no active quote, then it creates a new quote. It generates a quote line item to update the selected asset. If the product is a product with components, then the workflow displays the service item in Configurator with all related open orders applied to it. Otherwise, it displays the Quote Detail view. This workflow is shown in the following figure.
A user initiates this workflow by clicking the Modify button in the following views:
Accounts screen, Service Items view
Accounts screen, Account Summary view
Networks screen, Nodes view
Networks screen, Connections view
Networks screen, All Elements view
Orders screen, Order Entry - Line Items view
Workflow Description
This workflow does the following:
Gets the details of the current account.
Retrieves the active document (quote or order) for the session.
If the account is of type 'Residential' then the active order is retrieved. Otherwise the active quote is retrieved. See SIS OM Active Quote Sub-Process and SIS OM Active Order Sub-Process.
Gets the number of assets that the user has selected to modify.
If the user has selected only one asset, then the currently requested state of the asset is retrieved and displayed in the Product Configurator view. See SIS OM Edit Complex Asset Workflow.
If the user has selected more than one asset, then the currently requested state of each asset is retrieved and added to the active document. See SIS OM Edit Complex Asset Workflow.
Displays active document.
Associated Business Service Methods
The following table shows the steps in this workflow that call business service methods.
| Workflow Step | Business Service Method Called |
Count Selected Rows |
Get Selected Row Count |
Get Selected Row |
Get First Selected Row Value |
Edit Asset Selections |
Iterate Process For Selected Rows |
Go to Document Details View |
GotoView |
