Setting Up the SPA Approval Flow
Setting up the SPA approval flow involves defining a list of users who are required to approve SPA quotes and defining whether SPA approval is parallel or sequential.
This task is a step in Process of Setting Up Special Pricing Authorization.
To set up the SPA approval flow
  1. Navigate to the Administration - Application screen, then the Approval Admin view, and then click Query.
  2. In the Approval Item field, enter SPA Quote Approval, and click Go.
  3. In the Approval Flow Type field, do one of the following:
    • Select Parallel if only one user is required to approve an SPA quote.
    • Select Sequential if SPA quotes must be approved by multiple users.
  4. In the Approval Stage subview, define the list of users or positions that are required to approve SPA quotes.
