About Specifying SQL Logging and SQL Tagging for Siebel Application Object Manager Components
This topic is part of Analyzing Generated SQL for Performance Issues.
SQL logging and SQL tagging are diagnostic tools that log and tag SQL statements generated and executed by Siebel CRM. When used in conjunction with SQL logging, SQL tagging can help administrators trace long-running or slow-performing SQL queries back to the user or action that triggered them. You can also use these tools to review generated SQL in a development or test environment after making configuration changes in Siebel Tools.
SQL logging controls the level of SQL logging detail in a log file for an object manager-based component. To set SQL logging for a component, set the
Object Manager SQL Log(aliasObjMgrSqlLog) event to an appropriate value. For example, specify the event value for a Siebel Application Object Manager component such as Call Center Object Manager (ENU).SQL tagging controls whether or not
SELECTstatements are tagged for an object manager-based component. SQL tagging also controls whether or not to log additional information, such as the name of a business component. SQL tagging is primarily used during the development phase. To set SQL tagging for a component, set theOM SQL Tagging(aliasObjMgrSqlTag) event to an appropriate value. By default, SQL tagging is disabled.
With SQL tagging, data that can be logged includes the server component name, server name, task ID, user ID, flow ID (with Siebel ARM ID), business object name, business component name, and view name. Which elements are logged depends on the level set for the event.
For instructions on how to use SQL tagging and logging to log and tag generated SQL statements at the server component level, see Siebel System Monitoring and Diagnostics Guide.
