Enabling and Disabling Workload Tagging Using the Siebel Application
Use the following procedure to set the log level of the OCI SQL Tagging event type for the applicable Siebel Application Object Manager server component using the Siebel application GUI.
To enable and disable workload tagging using the Siebel application
  1. Navigate to the Administration - Server Configuration screen, then the Components view.
  2. Select the appropriate Siebel Application Object Manager for which you want to enable workload tagging. For example, if the application that you are using is Siebel Call Center for U.S. English, then select Call Center Object Manager (ENU).
  3. Click the Events subview, and then select the OCI SQL Tagging event type.
  4. Set the Log Level as described in About Enabling and Disabling Workload Tagging.
After workload tagging is enabled, database administrators can use Oracle Enterprise Manager to diagnose and troubleshoot the problematic generated SQL.
