Parameters for Configuring Siebel Product Configurator Caching
This topic is part of About Siebel Product Configurator Caching.
Siebel Product Configurator caching is enabled by default (eProdCfgSnapshotFlg is set to TRUE). Other
parameters must be sized following guidelines such as those described
in Determining Rough Sizing for Caching Parameters.
This topic lists the server parameters for configuring Siebel Product Configurator caching. Set these parameters on the Siebel Application Object Manager component for a Siebel Application Object Manager deployment of Siebel Product Configurator. For a dedicated Siebel Product Configurator server deployment, set these parameters on the Siebel Application Object Manager and on the eProdCfgObjMgr component, unless otherwise stated. For information on how to configure server parameters, see Siebel System Administration Guide.
Parameter Alias |
Parameter Name |
Data Type |
Default Value |
Description |
eProdCfgCacheFS |
Product Configurator - FS location |
String |
Not applicable |
Specifies the location of the Siebel Product Configurator File System. If no value is
specified for |
eProdCfgAttrSnapshotFlg |
Product Configurator - Collect and Use the snapshots of the ISS_ATTR_DEF Ob |
Boolean |
Set to |
eProdCfgNumOfCachedAttrs |
Product Configurator - Number of Attribute Definitions Cached in Memory |
Integer |
100 |
Sets the number of attribute definitions kept in memory at any given time during configuration. |
eProdCfgClassSnapshotFlg |
Product Configurator - Collect and Use the snapshots of ISS_CLASS_DEF Ob |
Boolean |
Set to |
eProdCfgNumOfCachedClasses |
Product Configurator - Number of Class Definitions Cached in Memory |
Integer |
100 |
Sets the number of class definitions kept in memory at any given time during configuration. |
eProdCfgProdSnapshotFlg |
Product Configurator - Collect and Use the snapshots of ISS_PROD_DEF Ob |
Boolean |
Set to |
eProdCfgNumOfCachedProducts |
Product Configurator - Number of Product Definitions Cached in Memory |
Integer |
1000 |
Sets the number of product definitions kept in memory at any given time during configuration. |
eProdCfgSnapshotFlg |
Product Configurator-Collect and use snapshots of the Cfg objects |
Boolean |
Set to |
eProdCfgNumbOfCachedCatalogs |
Product Configurator-Number of cached catalogs |
Integer |
10 |
Sets the maximum number of Model Manager catalogs that can be cached in memory. Catalog data is flushed from the cache on a least recently used basis. |
eProdCfgNumbofCachedWorkers |
Product Configurator-Number of workers cached in memory |
Integer |
50 |
Sets the maximum number of workers that can be cached in memory. This number applies to all Model Manager catalogs. |
eProdCfgCacheEngineObjects |
Product Configurator - Cache Engine Objects |
Boolean |
Set to Note: This parameter supports precaching. Set this parameter only on the dedicated Siebel
Product Configurator server. Precaching does not apply on the Siebel Application Object
Manager.
ServerSessionLoopSleepTime |
Server Session Loop Sleep Time |
Integer |
300 |
Specify an interval time (in seconds) to refresh cached products that are mapped to a Siebel Product Configurator server cache or component cache using the explicit product mapping setting.
Manager.
