Using the NUM_IFTABLE_LOAD_CUTOFF Extended Parameter with Siebel EIM
This topic is part of Troubleshooting Siebel EIM Performance.
Setting the NUM_IFTABLE_LOAD_CUTOFF extended parameter
to a positive value will reduce the amount of time taken by Siebel
EIM to load repository information. This is because when you set this
parameter to a positive value, only information for the required EIM
tables is loaded. For more information about this parameter, see Siebel Enterprise Integration Manager Administration
Guide.
Note: While this parameter is especially important for merge processes,
it can also be used for any of the other types of processes.
Here is an example of using this parameter while running on Microsoft Windows from the server command line mode:
run task for comp eim server siebserver with config=account2.ifb,
ExtendedParams="NUM_IFTABLE_LOAD_CUTOFF=1", traceflags=1
