Defining Compatibility Rules for Product Promotions
This task is a step in Process of Creating Product Promotions.
You might have policies that keep customers from using more than one product promotion at the same time. For example, you might say that a coupon for a product may not be used with other coupons for the same product, but that the coupon may be used with bundle promotions for the same product.
You can define compatibility rules for a product promotion to specify the other product promotions with which it may and may not be used. For more information, see the topic about compatibility rules in Siebel Order Management Guide.
To define compatibility rules for a product promotion
  1. Navigate to the Administration - Product screen, then Product Promotions view.
  2. In the Product Promotions list, select the promotion for which you are defining compatibility rules.
  3. Click the Eligibility and Compatibility Rules view tab and then in the link bar, click Compatibility.
  4. Add new records to the Rules list and complete the necessary fields, as described in the topic about compatibility in Siebel Order Management Guide.
