Specifying Product Lines or Product Classes for a Product Promotion
Use the following procedure to specify product lines or product classes for a product promotion.
To specify product lines or product classes for a product promotion
Navigate to the Administration - Product screen, then Product Promotions view.
In the Product Promotions list, select the promotion for which you are specifying products.
Click the Products view tab, and in the link bar, click Aggregate.
For each product that is covered by the promotion, add a new record to the Product Aggregate list and complete the necessary fields as described in the following table.
Field Comments Product Line
Select a product line that is covered by the promotion. Select either a product line or a product class, but not both.
Product Class
Select a product class that is covered by the promotion.
Complete the other fields in the same way as in the Components view.
In the Default Product view, click the Default check box for each product that is a default product for the promotion and enter the default quantity for each.
To enter descriptions of the promotion to be displayed in Edit Promotion view, add a new record to the Translations list for each language you support and complete the necessary fields in the same way as in the Components view.
