Assigning Siebel Configurator Interfaces to Users
After you have created custom user interfaces for all your users, you must assign each interface to the appropriate users.
This task is a step in Process of Creating a Custom Siebel Product Configurator User Interface.
You can create a number of Siebel Product Configurator user interfaces for the same customizable product and assign them to different users. This can be useful for the following reasons:
You can create a simple user interface for customers buying the product through the Web and an interface that allows quicker data entry for call center agents.
You can create a user interface with only a small number of options for salespeople doing indicative quoting, who need to select only a limited number of product options to determine price. You can create a user interface with all available options for technical designers, who need to select all product options before submitting the order.
Because several user interfaces use the same product model, maintenance is reduced.
You assign a user interface to users by associating it with a responsibility. Users have responsibilities that determine what views they can see. If you set up your application for reason (1), then you would have the responsibilities Web Customers and Call Center Agents. For reason (2), you would have the responsibilities Salesperson and Technical Designer. For more information about responsibilities, see Siebel Security Guide.
If you leave the responsibility blank, the user interface is assigned to all users. If you add another option with a specific responsibility to override the blank responsibility for some users, you must make the sequence number for this specific responsibility lower than the sequence number for the blank responsibility.
You can also control the UI option using SetUIOption Method.
To assign a Siebel Product Configurator user interface to users
Navigate to the Administration - Product, then the Product Definitions screen.
In the Products list, select and lock the desired customizable product.
In the versions list, click the Work Space version.
Navigate to the User Interface view.
Add records to the User Interface list and complete the necessary fields as described in the following table.
Field Comments Option Name
Enter the name of a custom user interface.
Option Type
Select high interactivity.
Sequence
Enter the sequence in which this record is checked. When a user clicks Customize, the application checks the records in this list in order of sequence, and it assign the user the first record it finds that is assigned to the user's responsibility and supports the user's browser.
Responsibility
Enter the responsibility that this user interface is assigned to.
