GetFieldValues Method
This method retrieves field values for a product that exists in the complex product.
Input Arguments
  • ObjId. The unique identifier of the complex object root (for example, Quote ID).
  • RootId. The unique identifier of the complex object root (for example, Quote Line Item row Id).
  • (Optional) Version. Version arguments are used only when testing a customizable product version that is different from the currently released version.
  • Path - the path to the item.
Output Arguments
The output property set returned will have the field names as properties, as follows:
< Field="value" Field="value" ... Field="value"/>
