GetParents Method
This method retrieves all the parents of an item.
Input Arguments
  • ObjId. The unique identifier of the complex object root.
  • RootId. The unique identifier of the complex object root.
  • (Optional) Version. Version arguments are used only when testing a customizable product version that is different from the currently released version.
  • Path. The path of the item.
Output Arguments
The property set returned will have child property sets, each with the following properties:
   < Product Id="value" Name="value" Sequence Number="value" Path="value"/>
