What's New in Siebel Product Administration Guide, Siebel CRM 20.12 Update
The following information lists the changes in this revision of the documentation to support this release of the software.
New Product Features in Siebel Product Administration Guide, Siebel CRM 20.12 Update
Topic Description
Overview of Product Administration
Modified topic. Deleted references to Oracle Advanced Constraint Technology. Siebel Constraint Engine is no longer supported for Siebel Product Configurator, as of Siebel CRM 20.12 Update. Siebel Product Configurator uses only the existing iLog integration. For more information, see the Siebel Installation Guide.
About Predefined UI Properties
Modified topic. Deleted references to Oracle Advanced Constraint Technology, and also deleted the property: EnableOraCfgEngine. Siebel Constraint Engine is no longer supported for Siebel Product Configurator, as of Siebel CRM 20.12 Update. Siebel Product Configurator uses only the existing iLog integration. For more information, see the Siebel Installation Guide.
About the Siebel Constraint Engine
Deleted topic. Siebel Constraint Engine is no longer supported for Siebel Product Configurator, as of Siebel CRM 20.12 Update. Siebel Product Configurator uses only the existing iLog integration. For more information, see the Siebel Installation Guide.
Process of Setting Up Siebel Constraint Engine
Setting Up the Siebel Constraint Engine System Preference
Setting Up the EnableOraCfgEngine UI Property
About Configuration Resources
