The following table provides a comparison between Siebel Remote
and Siebel Replication Manager.
| Siebel Remote |
Siebel Replication Manager |
Siebel Remote provides the following:
Supports data synchronization with remote clients
- Provides an extension of the Siebel database and file system for
each user
Provides access to local data while the remote client is disconnected
from the Siebel Server
Requires the user to periodically synchronize local data with
the Siebel database
Uses the same architecture as Siebel Remote
- Uses a hierarchy of nodes that is different from Siebel Remote
Supports server-based data replication in a hierarchical set
of Siebel Enterprise Servers
Supports multiple users in each replicated node
Synchronizes data between the parent node and the subordinate
nodes of the parent
