Configuring Traces for a Server Component by Using an Administrative Screen
This topic describes how to set tracing for a server component by using an administrative screen.
To configure traces for a server component by using an administrative screen
  1. Locate the record for the server component you must trace.
    For more information, see Server Components That You Can Use with Tracing and Locating the Record for a Server Component.
  2. In the Events list, choose the Event Type you must trace.
    To help determine the Event Type to choose, you can use the Description field. For more information, see Using Event Logging with Server Components.
  3. Set the value in the Log Level field to 4.
    The log file for the server component you choose in Step 2 will contain the tracing information.
