Patch Management
Implement a patch management process to make sure that all the software in your environment is updated with the latest software versions and security patches. You must make sure all updates and patches for Siebel CRM are applied. Also make sure that all updates are applied for the other software that is required to run Siebel CRM, but that is not shipped by Oracle. Some examples include your operating system software and browser software.
