Using Non-ASCII Characters in a Unicode Environment
  • For database authentication, the user ID and password must use characters that are supported by the Siebel database.
  • Login problems might occur if you log into a Unicode Siebel site, then use Web Single Sign-On to access a third-party Web page that does not support Unicode. Make sure all applications accessible from Web SSO are Unicode-compliant.
