Arguments for Get Work Item Info Method
The following table lists the arguments for the Get Work Item Info method.
Argument Display Name And Data Type | Argument Name | Type | Req’d | Comment |
Channel Type (type: String) |
MediaType |
Output |
Yes |
The language-independent channel type |
Channel Type Locale (type: String) |
MediaTypeLocale |
Output |
Yes |
The language-dependent channel type locale |
Description (type: String) |
Description |
Output |
Yes |
Work item description |
Driver Work Tracking ID (type: String) |
DriverWorkTrackID |
Output |
Yes |
The tracking ID of this work item in driver scope |
Icon File (type: String) |
IconFile |
Output |
Yes |
Icon file of the driver profile that owns this work item. The icon is also specified in the CSS file. |
Is Active State (type: String) |
IsActiveState |
Output |
Yes |
Indicates if this work item is active |
Is Data Contained Inside (type: Number) |
HasWorkData |
Output |
No |
Indicates if this work item contains data inside |
Is Inbound Item (type: String) |
IsInboundItem |
Output |
Yes |
Indicates if this is an inbound work item |
Parent Work Item ID (type: String) |
ParentWorkItemID |
Output |
Yes |
ID of parent work item |
Profile ID (type: String) |
ProfileID |
Output |
Yes |
ID of driver profile that owns this work item |
Profile Name (type: String) |
ProfileName |
Output |
Yes |
Name of driver profile which owns this work item |
Time In Queue (type: String) |
TimeInQueue |
Output |
Yes |
Time this work item stays in the queue |
View Bookmark (type: String) |
ViewBookmark |
Output |
Yes |
View bookmark |
Work Duration (type: String) |
WorkDuration |
Output |
Yes |
Duration of work item |
WorkItemID |
Input |
Yes |
Work item ID |
Work Item Key (type: String) |
WorkItemKey |
Output |
Yes |
Work item key |
Work Item Not Exist (type: Number) |
WorkItemNotExist |
Output |
No |
Work item does not exist |
Work Object ID (type: String) |
WorkObjectID |
Output |
Yes |
Object ID |
Work Start Time (type: String) |
WorkStartTime |
Output |
Yes |
Time work item started |
Work State (type: String) |
WorkState |
Output |
Yes |
Work item state |
Work Tracking Object Business Component (type: String) |
WorkTrackObjBusComp |
Output |
Yes |
Name of business component for after-work tracking |
Work Tracking Object Business Object (type: String) |
WorkTrackObjBusObj |
Output |
Yes |
Name of business object for after-work tracking |
