Enabling Client-Side SCAPI in Siebel Environment
This topic is a part of Siebel Client-Side Communications API for Cloud-Based Contact Center Integration.
To Enable Client-Side SCAPI in Your Siebel Environment
Follow these steps to get familiar with Siebel CTI driver development and Siebel Open UI configuration, for more information, see CTI Administration Guide: Developing a Communications Driver and Configuring Siebel Open UI: Customizing Siebel Open UI.
Enable Communications Session Manager in Siebel Environment.
Log into Siebel Call Center as application administrator.
Go to Siebel Sitemap -> Administration - Server Configuration -> Enterprise.
Enable Communications Management under 'Enterprise Component Groups'.
Make sure Communications Session Manager is assigned and enabled.
Restart Siebel Server.
Import Sample Definition File
Go to Siebel Sitemap -> Administration - Communications -> All Configurations
Create a new configuration.
Import sample definition file
CTI-sample.definto the new configuration. -
Associate this configuration to a CTI agent.
Configurations -> Agent
Configure Sample Driver
Launch Siebel Web Tools, navigate to 'Manifest Administration.
Add cticlient.js to Manifest Files using this path:
siebel/custom/cticlient.js. -
Create a New UI Object.
UI Objects Applet:
Type: Application
Usage Type: Common
Name: PLATFORM INDEPENDENT
Object Expression:
Inactive Flag: N
Expression: IsCommEnabled
Level: 1
Files:
Inactive Flag: N
Test your sample driver.
Log into Siebel Call Center as an CTI agent.
Launch Communications Panel.
The sample driver file should perform a set of tasks simulating agent UI transactions, for example: enable/disable CTI toolbar login and logout, enable/disable CTI toolbar buttons, trigger screen and view navigations, etc.
