@Phone Macro Example
The example command and associated command data shown in the following table and second table in this topic use the @Phone macro, which you can use to dial any phone field on any business component.
Parameter Name Parameter Value
Description
Make Call to "{@Phone}"
DeviceCommand
MakeCall
Hidden
True
The following table shows a command data definition for this command definition.
AttachContext
True
Param.CallNotifyText
Call from {@UserName}...
Param.PhoneNumber
{@Phone:PhoneTypeLookup}
RequiredField.@Phone
