Configuring the Common Logger for Siebel Application Interface
This task is part of Customizing the Application Container for Siebel Application Interface.
You can configure the log level for the Siebel Application Interface common logger, which is used for certain common logging tasks. This log cannot be configured using Siebel Management Console, unlike other types of logging for Siebel Application Interface described in Configuring the Siebel Application Interface.
If you plan to configure the log level for the common logger, it is recommended to do so after you finish configuring Siebel Application Interface using Siebel Management Console. After configuring the common logger, you must restart the application container, as described in Stopping and Starting the Siebel Application Container.
Note: Static content (such as scripts and images) are separated into a directory named siebelwebroot. This siebelwebroot can support symbolic links to shared directory having custom files. This avoids adding one more entry into server.xml. Customers can ow create symbolic link to shared custom directories in siebelwebroot. To share custom files for multiple AI instances. Network speed and file locking issue must be considered when pursuing this option.
Related Topics
Related Books
Siebel System Monitoring and Diagnostics Guide
