Installing Siebel CRM Using Silent Mode
The Siebel CRM installer supports an optional silent installation (also known as unattended installation) process, which is an installation that has been preconfigured to require no user input when the installation program runs. You can save a response file in a regular installer session. Then you can run the installer at the command line with certain flags appended to the installer command to execute the response file. Together, these tasks constitute installing in silent mode.
You can perform silent installations for better performance when installing software on multiple computers. Or, you might perform silent installations if user input during an installation is not allowed in your environment, as might be the case in some secure environments. A silent installation prepackages all of the required parameters so that you only have to execute a command to perform the installation.
The silent installation process for the current release of Siebel CRM is similar to that for Siebel CRM 21.1 and earlier. You can use silent mode to perform any installation task by the Siebel CRM installer or to add languages or components to an existing installation.
For silent installation, Siebel CRM includes the following files. You can use these files or save and modify your own response files.
enterpriseserver.resp
siebelserver.resp
When you create a new response file from running the Siebel CRM installer, the file is
         created as siebelinstall.rsp and is located in the
            SIEBEL_ROOT installation directory.
This topic includes the following information:
Related Topics
Installation Tasks for Siebel CRM
Installing Siebel CRM using the User Interface
Installing and Deploying Additional Languages
