Hierarchy of System Parameters
The following table lists the parameter-setting levels in order, from highest to lowest. Named subsystem parameters can apply to entities at different levels.
Level  |
System Parameter  |
Comment  |
1  |
Default from library  |
Default, hard-coded values from the library. Does not apply for passwords and other parameters that require user-supplied values.  |
2  |
Siebel Enterprise parameter  |
For more information, see About Siebel Enterprise Server Parameters and Configuring Siebel Enterprise Parameters.  |
3  |
Siebel Server parameter  |
For more information, see About Siebel Server Parameters and Configuring Siebel Server Parameters.  |
4  |
Siebel Server component parameter, enterprise level  |
Enterprise-level Siebel Server component parameters are set by configuring component definition parameters. For more information, see Configuring Siebel Enterprise Component Definition Parameters and About Siebel Server Component Definitions.  |
5  |
Siebel Server component parameter, server level  |
For more information, see About Siebel Component Parameters and Configuring Siebel Server Component Parameters.  |
6  |
Siebel Server component task parameter  |
Configure these parameters mainly for batch tasks or when invoking tasks from a script or a workflow process. For more information, see About Task Parameters, Starting a Component Job, and Configuring Siebel Server Task Dynamic Parameters.  |
