Parameters for DataSources Section
The following table lists data sources in the Siebel configuration file, which appear in the [DataSources] section. Each data source also has its own section specifying parameters that apply to this data source.
Name |
Function |
Local |
Defines parameters for connecting to the local database. |
Sample |
Defines parameters for connecting to the sample database. |
ServerDataSrc |
Defines parameters for connecting to the Siebel database. |
GatewayDataSrc |
Defines Siebel Gateway parameters. |
Note: If you want to prevent a data source from being displayed as
a choice in the Connect To: portion of the Siebel login screen, then
add two slash characters (//) in front of the data source in the [DataSources]
section of the configuration file. For example:
//Sample =
Sample.
