Navigation Section
This report limits the objects that are part of the application hierarchy. Nine tabs are displayed for each object type. When a tab is selected, it expands and displays the list of objects that are affected by the merge process. Two options provide searching capability for any particular object in the report:
Global Search searches any object in all objects of the application hierarchy.
Local search limits the search functionality to (for example) a particular tab on which a search operation is triggered.
