Running RepositoryUpgrade Utility
You can optionally run the RepositoryUpgrade utility on the development database to install new features since Siebel CRM 17.0 that require repository updates. This task does not apply if you do not require any of these new features.
For information about the new features that require repository updates, see Siebel CRM Update Guide and Release Notes on My Oracle Support for your Siebel CRM 22.x Update release.
The following procedure describes how to update the repository by running the RepositoryUpgrade utility, which is located in the siebsrvr\bin folder.
Note: Always run the RepositoryUpgrade utility from the Siebel Server home directory ($SIEBEL_HOME).
To run RepositoryUpgrade utility
  1. Run RepositoryUpgrade (RepositoryUpgrade.exe for Windows or RepositoryUpgrade.sh for other platforms) without any arguments to review the available command line arguments. The following tables describe the returned arguments and parameters, which you can use to run the RepositoryUpgrade utility.
    Parameter
    Description
    Example
    -s
    Siebsrvr installation path (Required)
    C:\$SIEBEL_HOME\ses\siebsrvr
    -t
    Siebel Table Owner (Required)
    SIEBEL
    -u
    TBLO Username (Required)
    SIEBEL
    -p
    TBLO Password (Required)
    -o
    ODBC Data Source (Required)
    Siebel_DSN
    -d
    Database platform (one of: Oracle, MSSQL, DB2UDB, or DB2390)
    Oracle
    -y
    Siebel Username (Required)
    SADMIN
    -z
    Siebel User Password (Required)
    -r
    Repository Name (Default: "Siebel Repository") (Required)
    Siebel Repository
    -g
    Primary Base Language
    ENU
    -w
    Additional Languages (Default: None)
    ARA,CHS,FIN,ITA
    -c
    SSE_ROLE (Required)
    SSE_ROLE
    -m
    Seed inp (data input) creation for the Migration Application (Default: Siebel Log Directory)
    Note: The RepositoryUpgrade utility will create a file named datamig.inp, which is required for the Migration Application to migrate seed data related to the repository changes from the DR to RR environment.
    C:\$SIEBEL_HOME\ses\siebsrvr\log
    -i
    Unicode DB (Default: Y)
    Y
    -6
    Generate Schema File Only (Default: N)
    Valid options are:
    • Y (Yes, generate schema file only) – This option generates a file with the required schema changes without actually applying them. This allows your database administrator to apply the schema changes to the physical database outside of RepositoryUpgrade.
    • A (Already applied Schema changes) – This option means schema changes are already applied. Use this option after the database administrator has completed the schema changes in the physical database.
    • N (No, don't only generate schema file) – This option means that you run RepositoryUpgrade to perform schema changes and import all other changes in one execution.
    Note: Use this switch to generate the required schema changes without actually applying them, thereby allowing your DBA to apply the schema changes outside of RepositoryUpgrade. For more information, see Independently Apply RepositoryUpgrade Schema Changes.
    N
    -9
    Parent Workspace Name
    Note: Best practice is to specify an Integration Workspace reflecting a planned future release (you will receive an error if you specify "MAIN"). This will allow you to merge the Oracle changes with your custom changes and test them before migrating them to Production.
    <Parent_IWS_Name>
    -b
    Default Tablespace
    Note: Mandatory argument for Oracle, DB2 UDB, and DB2390 databases.
    SEBL_DATA
    -x
    Default Indexspace
    Note: Mandatory argument for Oracle and DB2 UDB databases.
    SEBL_INDX
    -k
    16K Page Tablespace
    Note: Mandatory argument for DB2 UDB databases.
    TBLSPC16K
    -v
    32K Page Tablespace
    TBLSPC32K
    -4
    Provide a suffix for the log folder generated by RepositoryUpgrade. (Default: Null)
    Example: -4 Ora_23_11 will cause the log folder to be created as RepositoryUpgrade_Ora_23_11
    -4 Ora_23_11
    The following arguments are required only for DB2390 databases:
    Parameter
    Description
    Example
    -2
    4K Buffer Pool (Required)
    BP1
    -5
    8K Buffer Pool (Required)
    BP8K1
    -f
    16K Buffer Pool (Required)
    BP16K1
    -7
    32K Buffer Pool (Required)
    BP32K1
    -8
    Database Name Prefix (Required)
    D + Last 3 Characters of your schema qualifier
    -a
    Database Code Page (Required)
    ASCII/EBCDIC/UNICODE
    -j
    Index Buffer Pool (Required)
    BP2
    -e
    Storage Group for Indexes (Required)
    SYSDEFLT
    -h
    Storage Group for Tables (Required)
    SYSDEFLT
    Note: Don't use parameters that are inappropriate for your database platform. For example, don't use the DB2390 -j argument with Oracle, MSSQL, or DB2UDB databases.
  2. Execute the RepositoryUpgrade utility using values appropriate to your database. Examples for each supported database platform follow.
    Oracle example:
    RepositoryUpgrade.exe -s C:\$SIEBEL_HOME -t ORAXXXX -u ORAXXXX -p ******** -o Siebel _DSN
    -d ORACLE -y SADMIN -z ******** -b SEBL_DATA -x SEBL_INDX -c SSE_ROLE -9 int_1
    MSSQL example:
    RepositoryUpgrade.exe -s C:\$SIEBEL_HOME -t dbo -u MSXXXX -p ******** -o Siebel_DSN
    -d MSSQL -y SADMIN -z ******** -c SSE_ROLE -9 int_1
    DB2 UDB example:
    RepositoryUpgrade.exe -s C:\$SIEBEL_HOME -t SIEBEL -u SIEBEL -p ******** -o Siebel_DSN
    -d DB2UDB -y SADMIN -z ******** -b TBS_4K -x TBS_4K -k TBS_16K -v TBS_32K -c SSE_ROLE -9 int_1
    DB2390 example:
    RepositoryUpgrade.exe -s C:\$SIEBEL_HOME -t CQ10D0XX -u QADMIN -p XXXXX -o Siebel_DSN
    -d DB2390 -y QADMIN -z XXXXX -c SSEROLE -b SIEBTS00 -2 BP1 -5 BP8K1 -f BP16K1 -7 BP32K1
    -8 D003 -a ASCII -j BP2 -e SYSDEFLT -h SYSDEFLT -9 int_1
  3. Review the returned output. Output similar to the following is expected:
    Current Content Version : 21.3
    Current DB Version : 19.12
    Following builds available in the installer
    20.3
    20.7
    21.3
    Following builds need to be installed
    20.3
    21.3
    Schema Installation Starts
    Starting for each build
    Running for 20.3
    Running for 21.1
    Skipping: No Schema present for 21.2
    Running for 21.3
    Completed for each build
    Publishing Table Starts
    Sync Logical and Physical Schema
    Publishing Table Completed
    Schema Installation Completed
    Repository Import Starts
    Running for 20.3
    Skipping: No Repository present for 21.2
    Running for 21.3
    Deliver Workspace Starts
    Deliver Workspace Completed
    Repository Import Completed
    Seed Import Starts
    Running for 20.3
    Running for 21.2
    Skipping: No Seed present for 21.3
    Running Seed Copy for LOV for each branch
    Seed Import Completed
    Manifest Import Starts
    Running for 20.3
    Skipping: No Manifest present for 20.7
    Running for 20.8
    Running for 20.9
    Skipping: No Manifest present for 20.10
    Skipping: No Manifest present for 20.11
    Running for 20.12
    Running for 21.1
    Skipping: No Manifest present for 21.2
    Skipping: No Manifest present for 21.3
    Manifest Import Completed
    *** Integration Branch : int_siebel_update ***
    *** Workspace : dev_sadmin_siebel_21_3 ***
    *** Please review Web Tools -> Archive -> SIF Attribute Differences and resolve any
    conflicts. Once done, click Apply Changes to apply your decisions. If you do not make any
    changes in the report, all incoming configuration will be used. Once you checkpoint or
    version the Workspace, the Apply Changes option will be disabled. ***
    RepositoryUpgrade Execution Report Location : C:\$SIEBEL_HOME\ses\siebsrvr\log\RepositoryUpgrade_20210204_044026.html
    Check the HTML file (RepositoryUpgrade Execution Report) for more details, resolve any issues, and then rerun the process if required.
    At this point, RepositoryUpgrade will have created two new Workspaces in the repository, as follows:
    • An Integration Workspace named int_siebel_update_X directly underneath the Workspace specified by the -9 parameter (provided on the RepositoryUpgrade command line).
    • A Developer Workspace under this Integration Workspace named "dev_sadmin_siebel_mm_dd", where mm_dd represents the release you are importing, such as 23.10.
      Please review Web Tools -> Archive -> SIF Attribute Differences and resolve any conflicts. Once done, click Apply Changes to apply your decisions. If you do not make any changes in the report, all incoming configuration will be used. Once you checkpoint or version the Workspace, the Apply Changes option will be disabled.
      The Developer Workspace was used to import the Repository changes. This Workspace can be used to inspect all the RepositoryUpgrade-supplied changes and resolve any conflicts before delivery to the parent Integration Workspace. For more information on this, review the section Viewing and Resolving Conflicts after Siebel Archive File Imports in Web Tools in the Using Siebel Tools guide.
      After completing the conflict resolution, deliver the Developer Workspace to its parent Integration Workspace.
  4. Rebase the int_siebel_update_X branch to its parent Integration Workspace and test it in conjunction with your customer changes.
  5. Once you are comfortable that your changes and the RepositoryUpgrade-supplied changes work together, deliver the int_siebel_update_X branch to its parent Integration Workspace.
    Depending on your specific implementation and any conflicts that may exist, this process may require a Rebase, Conflict Resolution, Submission for Delivery, approvals in Siebel Approval Manager, and so on. For more information on delivering changes from a Workspace, see the Using Siebel Tools guide.
