Values Required by Post Installation Database Update
During the Siebel Enterprise Server installation process, you must provide database credentials and other information to successfully run the PostInstallDBSetup utility. Siebel Enterprise Server installer will attempt to prepopulate these values from the contents of existing master_*.ucf files generated during the original installation or update of Siebel CRM from a previous version. The order that the installer will check these files is as follows:
  • The master_install.ucf file, which is created during a fresh installation of Siebel CRM.
  • The master_upgrade_dev.ucf file, which is created during the update of Siebel CRM from a pre-Siebel CRM 17.x version.
If neither file is located or any required information is missing from the files, then you must enter the database information manually into the installer as described in Database Configuration in Siebel Enterprise Server Installer.
