About Process Log Files
You can identify errors you encounter during an upgrade by reviewing
the log file named UpgWiz.log (Windows) or srvrupgwiz1.log (UNIX)
in the SIEBEL_ROOT\LOG\process\output directory
(Windows) or the SIEBEL_ROOT/LOG/process/output
directory (UNIX).
The name of the log file increments for subsequent log files that are created if the Siebel Upgrade Wizard encounters a problem and you run the Siebel Upgrade Wizard again.
Review the end of the log file for details about the latest failure.
If the step that failed was not a native SQL step (which would be
listed in the log file), then it occurred as part of an external utility.
You can review the relevant log file, which is identified by the/L
parameter.
