How to Locate Upgrade Driver Files and SQL Scripts
Driver files are stored in the following location:
Windows: DBSRVR_ROOT\DB2390\UPGRADE\ VERSION
UNIX: DBSRVR_ROOT/DB2390/UPGRADE/ VERSION
where VERSION is the version from which you are upgrading, for example v8.1.1
For example, if you are upgrading from Siebel CRM 8.1.1, the driver files for the development environment upgrep are as follows:
driver_upgrep_dev_811_mf_m.ucf
driver_upgrep_dev_811_mf.ucf
Related Topic
About the Siebel Database Configuration Utilities and Database Configuration Wizard
