Log Files That Can Be Ignored
If the upgrade completed successfully, there are several log files that you can safely ignore:
Windows: sw_cfg_xxx.log and siebel.log
UNIX: srvrupgwiz_*.log and siebel_*.log. For example, srvrupgwiz_001.log, and srvrupqwiz1_02.log
Any other log file that existed before the start of the upgrade
Caution:
UNIX Only: The log file srvrupgwiz_001.log
is a different file than srvrupgwiz1.log
. Do not
ignore log files named srvrupgwiz1.log
, srvrupgwiz1_01.log
and so on.
