Executing a Migration Plan
You can execute a migration plan for your migration by sending an HTTP POST request to the Siebel Migration Application.
If you selected a Schema Service with Export & Import or Import only for your migration plan, then you must provide the following parameter and value in your REST API request:
schemaPassword. The password for the schema user. The schemaPassword must be encrypted by using base64 in the REST API request.
If you selected the Incremental Runtime Repository or the Incremental Application Workspace Data Service or the File Prepare and Deploy Service with Export only for your migration plan, then you must provide the watermarkFilename parameter and value in your REST API request.
If you want to only migrate a specific version when run the Incremental Runtime Repository (Export & Import or Export only) migration, then you must provide the irrEndVersion parameter and value in the REST API request. If you do not provide the irrEndVersion parameter and value, then, the migration migrates up to the latest version.
For all Export only or Import only migration plans, you must provide the packageFilename parameter and value in the REST API request.
The following details are for a request to execute a migration plan:
URI:
https://{hostname}:{port}/siebel/v1.0/migration/execution/{planName} -
HTTP Method: POST
Content-Type: application/json
Authorization: Basic
Request Body:
{ "schemaPassword":"", "watermarkFilename":"", "irrEndVersion":"", "packageFilename":"", }
The following are the details for the response to a successful request:
HTTP Code: 200
Response Body:
{ "id":"88-1V5YFC", "planName":"Data Mig", "description":"Data Mig", "status":"Running", "startDate":"2018-07-24 09:50:20", "endDate":"", "source":"Dev", "target":"Prod", "packageName":"", "resources":[ { "id":"88-1V5YFD", "name":"", "operation":"Export", "sequenceNumber":"1", "mode":"Asynchronous", "status":"Not Started", "startTime":"", "endTime":"", "resourceType":"" }, { "id":"88-1V5YFE", "name":"", "operation":"Import", "sequenceNumber":"2", "mode":"Asynchronous", "status":"Not Started", "startTime":"", "endTime":"", "resourceType":"" } ] }
