Stopping the Siebel Upgrade Wizard
Do not stop the Upgrade Wizard unless you are confident that an error has occurred, and the Upgrade Wizard or a utility it has called is hung. Some SQL commands issued by the Upgrade Wizard or by its utilities can take considerable time to complete.
If you are unsure whether or not the Upgrade Wizard has stopped responding, create a service request (SR) on My Oracle Support. You can log service requests by accessing My Oracle Support (Service Request tab), or by using your existing phone support numbers to contact Oracle Global Customer Support.
Stopping the Upgrade Wizard can have varying effects on the RDBMS. Before restarting the Upgrade Wizard, review the upgrade log files. Run SQL commands as required to resolve errors found in the logs.
The following procedure describes how to stop the Upgrade Wizard in a Windows environment.
To stop the Upgrade Wizard under Windows
Do one of the following:
If the Upgrade Wizard has launched a separate command window in which a utility is running, close the command window. This terminates the utility and stops the upgrade.
In the Upgrade Wizard dialog box, click Cancel.
The Upgrade Wizard will exit when the current upgrade step is completed. There might be a delay while the step completes.
The following procedure describes how to stop the Upgrade Wizard in a UNIX environment.
To stop the Upgrade Wizard under UNIX
If the Upgrade Wizard has started a utility in a child process, stop the child process.
Exit the shell in which the Upgrade Wizard is running.
Locate and stop any orphaned child processes started by the Upgrade Wizard.
After the processes terminate, there might be a delay while the RDBMS executes SQL commands that have already been issued.
