Using Shortcut Keys to Run a Query
You can use a shortcut key to run a query.
To use shortcut keys to run a query
In the Object Explorer, click the object type that you want to locate.
In the Object List Editor, enter
ALT+Qin Web Tools.In the Object List Editor, enter the query.
For more information, see Simple Query Operators and Compound Query Operators.
Press the ENTER key.
The query results are returned.
