Viewing System Task Properties of a Task
You can use the Task Properties list or the Multi Value Property Window (MVPW) pane to view the system task properties of a task.
To view system task properties of a task
Locate and select the task that you want modify.
To view the task properties for the selected task from the Tasks list, expand the Task tree in the Object Explorer, and then click Task Property.
The Task Properties list shows all the task property definitions for the selected task.
(Optional) To view the task properties for the selected task in the MVPW pane, open the Task Editor.
The Task Editor shows the MVPW pane with all the task property definitions for the selected task. For more information, see Opening the Task Editor.
