Configuring How Siebel CRM Displays Text From Field Values
You can configure how Siebel CRM displays text that it gets from field values.
To configure how Siebel CRM displays text from field values
Open the relevant configuration file in a text editor.
Add a separate line for each parameter you must specify, using the following format:
parameter_name = value
where:
parameter_name is one of the following parameters:
TreeNodeFontStyle
TreeNodeFontSize
TreeNodeSelectBgColor
TreeNodeSelectFgColor
The term caption that Siebel CRM displays in the parameter refers to an icon or graphic. It displays the caption as an image and positions it in one of the following ways:
Precedes the text that Siebel CRM creates from a field value
Precedes another caption
