Determining Technical Fit for Reusing a Predefined Object
This task is a step in Process of Determining Whether You Can Reuse a Predefined Object.
To determine technical fit for reusing a predefined object
  1. Examine the following technical factors:
    • Performance factors
    • Size and type of columns and fields
  2. Examine the following table schema factors:
    • Determine whether you must set columns to a default value.
    • Determine whether you must configure Siebel CRM to update the user key and unique index columns.
    If you must perform a large amount of customization to use an unused table, then technical fit diminishes.
  3. Determine the affect that the foreign key relationships have on Siebel Remote.
    Foreign key relationships and Siebel Remote are closely interrelated. Simply using the correct foreign key might not make sure that Siebel CRM downloads the data to the Remote client. You must determine how reuse affects the dock objects and the rules that interact with the foreign keys. For more information, see Configuring Dock Objects for Siebel Remote.
  4. Determine the affects that foreign key relationships have on visibility.
    Many columns that are not foreign keys can affect visibility. For example, S_PROD_INT.ENTERPRISE_FLG with a value of Y provides partial docking visibility to the product record. Misusing these columns can result in a significant negative affect on Siebel Remote.
