Predefined Localized Help
Siebel CRM comes with predefined localized help. Localized help files are located in the language folders on the Siebel Server or the Siebel client. Help files are installed in the following location on the Siebel Application Interface:
SIEBEL_AI_ROOT\applicationcontainer_external\install_language\help
where:
SIEBEL_AI_ROOT is the directory where you installed Siebel Application Interface.
install_language is the language you chose during installation.
